how much is it to get one put in (supplied and fitted)
They are about $120 I believe supplied and fitted.
I had 1 on my lancer when the extractors and system went on.
the pure reason has been stated but also its for noise as well
everytime ur engine moves ur exhaust would move but at the flange it would scrape and make a squeeky noise.and if that pisses u off u would just get it changed.but yeah in having a flexi join it wont cause ur exhaust to move as EVERYONE has said...
another alternative would be to use the donut that u can purchase from honda, alot of ppl i know use this instead of the flex pipe, the donut goes in the flange with the spring loaded bolts providing enough flex to the exhaust system when it does move.
It is the same as the stock system they use with ur car except, if u have a 2.5" collector on ur header u will need to purchase the s2k donut from honda as it is a larger size donut.
can ourchase form one of the traders we already have on the forums too!
Honda Header gasket ring 2.5inch - $50
http://www.ozhonda.com/forum/showthread.php?t=27088
does stock flange hav spring loaded bolts ?
