A Gsi doesnt have any cross members like a LS you have alot more clearance and front room in that
2 issues you will have,
the bottom of the headers will hit the sump of a b18a,
and the lower portion where it meets the cat is shorter.
b16a headers wont fit on a b18a block as it hits the sump. Unless they are a mugen 4-1 copy headers where they are able to fitt all b series with the sacrafice of hanging lower.
4-1 copys also require you to notch and box section your lower bar.
I know because i have had all these headers and lernt by first hand experience.
im pretty sure that they fit, cause all b series engines are the same fit...
but if your wanting some dc2 vtir headers. i got some laying at home if your interested.
with the heat shield. but these should fit striaght on.
b series are not all the same fit, the b18a is the exception.
Correct me if i'm wrong but i think the 02 sensor is in a different position for LS?
Just ordeer a set from X-Force, speak wit EGSI from here on Ozhonda, he will hook you up and he has great bloke to deal with.
yes it id you might have to extend the wireQuote:
Originally Posted by bennyBear
in an LS its only one so thats pretty easy
