I only get an alignment when the tires are changed. $50 is heavy for a jazz's wheel alignment. Correct me if I'm wrong only the front has adjustments nothing can be done about the rear?
No need for another one, unless you have hit a kerb or large pothole that could've moved something there.
I have been through this issue on a camry. A worn suspension bushing can cause un even tire wear.
