Find an imported EF instead :)
I think it is easier to do the wiring yourself!!!!Quote:
Originally Posted by Setanta
Having helped in the wiriring process, it is a few hundred hours worth of work... did an EG Breeze with an H22 - NEVER AGAIN
If you do have a carbie engine i hope you have saveed up more than 5grand to do this properly.
It is an expensive and long conversion if you go bigger than a B16A,
is it alot less work when going from FI to FI??
EFI? u mean ?
Of course it is - ll the FI stuff is on the car ready to go :)
I never thought there was that much work in the going from carby to EFI?
What sort of difficulties are you all talking about?
wiring
ecu
What exactly do you mean when you say just wiring and ecu?
Are you just talking about plugging them in? Because thats pretty straight forward I'm guessing?
well carbie cars dont have computer, no comp = no wiring and no place to just "plug it in". so you have to add all of that in.Quote:
Originally Posted by CAT_SPEW
Aww okai, I though mine did have a computer lol. Well I found what looked to be a computer on the floor under the carpet on the passenger side. Anyway, I will be getting the ECU and wiring with my half-cut so I guess all I need to hink about is getting the wiring through the firewall and the tank and new lines hooked up right?
nah...carby cars have ecu but they r much simpilar than the EG5 or any EFIed carsQuote:
Originally Posted by Toby
and wiring and the ECU..CAT SPEW as i told u b4 just ransfer everything off the other car into your car..
and..dont forget to get a surge tank or a EFI fule tank off a EG civic..
