Hmm i hope ya not talkin about meeeee. All i can say is compare the prices and go the cheaper option cos they are both very similar kits. I have had no problems with my kit.Quote:
what kit did you use?
AVO kit and had no dramas with it
send a pm to Qball.
he will help ya out man.
and yes.. it is worth to turbo the gsi however reliability relies on the curent state of ur engine and the installer/tuner so go to a reputable workshop.
and u will definately need a new clutch :)
thanks for the info TECBOY. Ill have a look more into it. :)
lol, yeah I wimped out at the last minute cos I wouldn't be able to afford it if my engine blew :oQuote:
Originally Posted by GSI-PSI
When I spoke to AVO though they said they had no problems with the Integra kits so yeah :thumbsup:
How much boost does the AVO kit provide ?
u can put a bolt on turb kit on a stock gsi engine no probs and pull some great times down the 1/4, as well as some good power figures.Quote:
Originally Posted by bside
thing is, if u do so, even though some ppl will say u can run 8-10psi all day everyday, i still wouldnt run more than say 6psi on stock internals. ive jst known one too many ppl that have boosted their car up that tad bit too much and the result has been a blown motor.
the way i see it is if u install a turb kit, u should base ur decision on the state of the engine, running something thats safe for it, that wont blow it up.
doin internal work such as pistons, rods, bearings etc will definately put ur mind at ease as u know that the engine will be able to handle the pressure successfully.
if u aint gona go crazy for power, then an AVO kit or similar running about 6psi on stock internals should do u very well as both ur weekend and everyday driver :)
ill be goin down the greddy road but the inclusion of the e-manage makes it realy tunable.
the kit has everyhting minus the frontmount
where you get the greddy kit from?
Qball: thanks for the reply. i thought i would change alot of the internals, once the kit is mounted. but if I could run stock for a while, then thats more then good enough, well at least for now.
The ppl you know who have blown their motor, how much rpms did they go up to before it blew? and what gear?
A kit is good with stock internals. If you going to get stronger internals your opening the door for some awsome power where your off the shelf kit will then be limiting you. If your going to do your internals you might as well get a custom set-up and you'll get a lot more out of you worked motor. If you happy with just a kit I would keep the motor stock.Quote:
Rpms don't blow your motor, heat and detonation will. :thumbsup:
