Perhaps. Let me clarify..I was refering to running stock injectors on a stock turbo motor (that was the original point)Quote:
Originally Posted by Weq
The motor will not cope with a lean condition, which stock injector will most definate cause under boost.
Honda run injectors at over 80% duty cycle from factory.
And even though you could probably push them to 90+% duty cycle, its not such a great idea.
And even if you did, we're only talking capacity for about 2psi boost at the most.
I wouldnt be happy with 2psi boost after spending a few thousand for a turbo kit.
