you cant verify, unless you do your own reverse engineering of a genuine spoon ecu.
Yes, mine are genuine.
- but we cant verify that either can we?
not having a go at you
just want to know what the difference between a spoon ecu and other aftermartket ecu's would be like?
no, you cant verify it, but they are probably genuine copies of the program.
as far as i know, it is easy to program chips with genuine programs, all you need is the source code, then use a chip burner to make lots of 'genuine' copies...
micheal - you asked me about chipping, but ProECU is the man to talk to ;)
Correct.Quote:
Originally Posted by michael_antoi
As I said before, you can't easily verify its authenticity, unless you can reverse engineer a genuine item.
i dont know a lot about chipping/ecu's
but couldn't u just compare the fuel maps, ignition timing that set on the spoon chip?
So Evan is a good chipper :pQuote:
Originally Posted by tinkerbell
ALLMTR996
soo, which would be the better option?
