Thats a OBD2a ECU, Not a OBD1 ECU. Who every informed you is wrong.
Regards James
Regards James
Gees so many different people claiming to know things!!! grrrrr
I dont mean to throw another spanner in the works mr dUy :p but i was under the impression that pre 96 is OBD1, Post 96 is OBD2?
John clear this up for both Duy and myself?
James knows his ecu's so it's OBD2. I was told that OBD2 all had engine immobilizer but my car doesn't from the key. Bloody confusing.
ok that key is defenantly OBDI and that ECU is OBDII
what some people do is butcher their OBDII key and take the transponder out of it and stick it near reciver, then they can use type R keys or any other key that fits.
can yo take a pic of your ignition lock of the teg, sorry to be a pain in the ass.
Kool thanks heaps John, will take another pic tomorrow :)
on the EK's the engine loom is a one piece loom that goes through the firewall and plugs directly into the ECU under the dash on the passenger side.
So you will ask yourself which loom do i Use? The DC2 engine loom has connectors terminating just after the firewall... If this were to swap in a EG it would be plug and play unfortunately its not as easy for an EK!
97 ecu connections should be OBD2A (looks like it on the pics), I would totally utilise the CXi engine loom fit that on to the B18C, add the missing wires and add/extend any wires/sensors that are missing such as VTEC, KNOCK, IAB control and also you will need to wire up the heated O2 (4-wire) as the CXi from memory is single wire.
As for the immobilizer there is a bypass method but if your 97 ecu doesnt have a onboard immobilizer then you might get away with it... However on the EK's they have a separate immobilizer relay unit that I have seen on some models...
all AUDM EK's have the Immobilizer control unit under the dash
Pics of the ignition
http://users.tpg.com.au/duydang/b18c/b14.jpg
http://users.tpg.com.au/duydang/b18c/b13.jpg
Do these pics help at all?
that teg has no immobiliser
lucky you
Awsome, thanks for the info. Will no doubt need more help once i start. :)
