ops
dc2 = type r = the car im talking about..
vtir = different again ;-) much less power.
Regards James
ops
Regards James
With vti-r's, 7psi is that on stock internals ? 140kw atw is good, going NA would you be able to achieve the same result for the same price ?
i refuse 2 promise KW figures to any of my clients, NO ONE can predict how much power a car will make !! having said that there are only guidelines...
A dyno is a tuning tool not a accurate power output device !
were building a $25,000 b20 engine ATM and that’s expected to make 130kw - 140 at most but at the end of the day it all depends.
Regards James
none the less it will still be a quick car 130fwkw on such a light car :D
reliability should be number one priority IMO.
Reliablity is no1 and also quality this thing will rev to 11,000rpm ;) easy !!
Regards James
dayum!Quote:
Originally Posted by BLKCRX
:P
has Razz Tech got an address and phone number?
Call me and ill give you the required info... - 0417 875 785
Regards James
for a basic turbo setup, u are looking at 5k + tuning if u do it urself. if u get a workshop to do it, ur gonna pay around 2k in labour and markup on every item.
The thing about a turbo is, maybe u will only gain ~8kw per psi, but u have a good 8-12psi to push on a stock engine, depending on turbo and mangement.
im gettin about 165 wheel kws. runnin on 10psi
160-ish on 4.5psi
160ish on 8 psi
oh wait, that was a d16, not a b18c...
