if you give me your OBDII Dizzy Connector you removed, Ill disable your Immo for you :)
Just one more question on immobolisers. Does the ecu read any engine code number? For example, an OBD2 car with immo and we change only the engine, using same ecu, harness, key etc.. Will the ecu reject the engine?
i think that it must be ok to do that and the imobilizer is in the wiring or igniton barrel or something... Only a guess but im sure proecu or ecu man or someone will know
you can just swap engines, there is no problems with that
all the keys, PGMFI ECU, and IMMO control unit are all paired, meaning you cant just change a key, ecu or immo CU without reprogramming with the HDS ( Honda Dealer Job )
correct,
If you have an aftermarket alarm system, just do away with the immo, its more hastle than its worth.
