Damn!!!!!!!! That Looks Hot!!Quote:
you can find info on them at http://www.d2racingsports.com.au/d2suspension.htmlQuote:
Originally Posted by Boost Cruisin
i got mine thru PLYBOY here on ozhonda at $1300 a set.
They are shipped from NZ so you have to take into account customs duty. They were sent as 'valued $1000' so you only have to pay GST 10%.
So about 1400 all up for a set thats 36 way adjustable. They bolt straight up to your front forks so you dont have to swap them out like others. Installation can be done by yourself, or about $100 from a shop. Otherwise i'll do it for you at $99 :)
my car looks alot better now thats over a year oldQuote:
Originally Posted by Jnr_Mint
its a bit lower aswell
I just couldn't go on with out replying to this on :D
I have the Jackson Racing track set up on my teg it consists of Jackson racing coil springs with Tokiko Illumina shocks that have 5 damping adjustments and a Jacksons racing rear sway bar.
over all my car has been lowered 4inches from stock.
if I were you and just going for looks I would replace the springs and shocks, I say shocks coz you will find that you might be bottoming out quite a bit on lower springs and the standard shock may not last long, regardless of height, I've seen it happen to heaps of my mates cars.
heres a pic when mine was lowered on 18"s
http://img161.imageshack.us/img161/1...teg22hh.th.jpg
are there any other coilovers available for the DA9 apart from D2 and tein SS? cos im considering getting some of those D2 coilovers
ofcourse you can use coilovers from a DC, but that would require dc front forks and rear LCA.. I believe i posted a topic a while back with a list of avail coilover kits.
http://www.ozhonda.com/forum/showthr...light=coilover
Yep you're rightQuote:
Originally Posted by ACTI0NMAN-1
Ommni power also make Coilovers for our cars, but like ACTIONMAN-1 said most or all DC2 Coilovers will fit if you replace the front forks and rear lca's.
I have actually just gotten a quote from password jdm on a set of Ommni power coils for $1150 AUD landed and an extra $75 can get me a set of Tein Basics........
Im pretty sure you only needed to replace your rear lca's if you wanted to put DC2-R coilovers... When using DC2 coilovers it was only the front forks.
