this one issernt that easy ive tried. theres no bits hanging out and its about 1-2mm deeper then flush. suckz hard man ! :(
yeah, thats useually the go. did you try what Ben said.
I use a pointy pin type of tool. and screw it out.
if you have a dremel, cut a lil slot in the broken bit and use a falt head screw driver and screw it out, works everytime. goodluck
^^^ bout to say the same thing
Cant u just drill it out, like use a drill buit slightly smaller than the bolt. (plz dont try this until others have given pros and cons as i have no idea if this can damage other things)
im havin the same problem as this guy though the bolt snapped while fittin my carbon bonnet....
if i get this tool peice will it damage the fibre glass surroundin the thread where the bolt is stuck in to???
