PCV? My ZC is eating oil as well despite a slow CAM seal oil leak, a DIY would be awesome.
cheerz.
cheerz.
dude - check the DIY section..."Wynode" did a write up for the camseal replacement ( and i did a DIY for other upper gaskets too)Quote:
Originally Posted by EuroDude
Chi i should be free wednesday/thursday - lets keep it to MSN la
stop worrying about where its gone and fill her up!
How bout you also get a compression check before you go out and buy a bunch of parts. Figure out the problem first then fix it. If the rings are bad on the pistons why buy a pcv valve?! The pcv valve actually costs more then a new set of rings... Although it takes a bit more to change the rings!!
Cheers, ill have a look.Quote:
Originally Posted by bennjamin
btw I figured having a small oil leak can be a positive thing since the oil is always being topped up, lessening the need for an oil change every 5000km. Unless its a major oil leak off course.
