HUH? and why would u use a more runnier oil when your car starts blows smoke. doesnt make any sense...Quote:
Originally Posted by aaronng
i hope u know what the upper range figure means right
Upper figure indicates the viscosity for 100ºC, lower figure indicates the viscosity at -18ºC. With our climate, we can use 0w, 5w, 10w and even 15w because we rarely go below zero (if you live in the mountains where it snows, then you'll need 0w, 5w or 10w). At operating temperature, the upper value is more important and a higher viscosity at 100ºC assists in reducing blowby in older engines.
mobile 1 or honda FEO, they both are good enough !!!Quote:
Originally Posted by furiouswilly
i use mobile 1 personally.... :rolleyes:
Agree on the Mobil 1 ....and if I need oil on road trip somewhere, Mobil 1 is very easy to get.Quote:
Originally Posted by dc-r
chosing a good oil is a major contributor to your engine's performance and longetivity.
you can chose the viscosity from this chart:
http://img166.imageshack.us/img166/33/oilchartmj8.jpg
Make sure you use an oil that says "API service SG or SH", this oil is formulated to help your engine use less fuel.
as you can see 5-30 is not recommended in 40C heat in the summer. 10-40 would be the best way to go during winter, and 20-50 during summer.
Super thread revival....Quote:
Originally Posted by mj3610
Which car is that chart from? It varies for each model. Here's the one for mine:
http://img140.imageshack.us/img140/1...scosityfo1.jpg
You should use SL or SM oils. If you are in a pinch, SJ will work but you might get a little gumming depending on the oil's formulation. Oils from the SG and SH (for engines before 1996) era might gum up under the heat and relatively high compression of current engines.
the chart i posted is for a 94 accord VTi, which has a f22b1, sorry i forgot to mention before. +1 rep for u aarong :)Quote:
