your car is N/A as is mine and i can understand your need for more POWAH. but i think best way to go would be a engine swap or a N/A tune up. all the fun stuff like cams ,cam gears, ecu and all hte other bits that make your normal N/A car in to a beast of the line. No Turbo = no spooling up. if you get a good set up you can have the POWAH on hand ready to go. kinda like a super charger but with less fuel consuption :p. if you did go down the road of a bolt on turbo with stock internals running low boost i think you will find in time you may want to up the POWAH, so again that would be more money ontop of the money you spend on the low boost turbo you just bought :P OMG .but yes good luck on what you want and like the guys have said budget above what you are thinking, its a good idea :D. N/A POWAH :honda:
