Originally Posted by Dxs
Do u normally get oil on the timing belt if the crank pulley gasket is leaking?
yes
also there is oily residue around further down the car.. would that just be oil blown there?
yes
might get a new gasket and different gasket sealant and maybe try tinkerbell's technique.. so tink did u put alot of gasket on and on both sides of the gasket?
no hardly any, like lightly buttered toast, very little sealant was squeezed out when i torqued it.
what brand gasket sealant u use too..
no *brand* - just "RTV (room temperature vulcanizing) silicone sealant"
estimate of torque?
"screwdriver tight" is what i used - i.e. i used a 10mm socet on the end of a screwdriver... then a 1/4 turn with 15cm long ring spanner...
and other feedback?
