Had a look at this doc and this may not be a problem if I can get the specifications of the LED's used which should be available from the manufacturer. Seeing that it's not the first time LED's have been used/approved in OZ it should not be an issue.Quote:
Originally Posted by yfin
The only problem I can see may be with the angle of light needed, in some case 85 degrees from the centre to the side of the car. This may be an issue with the LED's. I noticed that the Mazda 3 LED taillights have some chrome reflectors that could be for this reason. Will need to look into this further.
With regard to the intensity of the light, this doc only mentions that the brake light needs to be brighter than the normal taillight. Maybe this detail is in the ADR.
