come on - you can work it out!Quote:
Mate does the e-manage come with the timing & injector options or are they an added extra?
they come as part of the ECU and you can program them yes. But to be able to do that you need the two 'seperate' harnesses - which are extra.
so i guess if you had someone to copy you might be able to make your own harness?
original ignition and injector harness's are available at a cost of approx $60/$70 each - why would you want to make them? just buy them. Cost more to make than to buy.
This harness I got simply makes the installation into the car much easier. no need to cut wired etc - and this one is available from the US.
yes ok this thread has inspired me 2 get a e-manage plug n play harness myself
As I said - the company who I got my harness from also has harnesses for the VAFC and SAFC as well as other applications.
PM me for information.
Mike
So what are you hoping to gain from the emanage?
im estimating between 5-10HP gain just on the tune.
But given the Cams and gears id estimate anywhere between 20-30hp. Hopefully 120-130@wheels with a good tune.
Well that's all fine an dandy then :D Good luck with it :thumbsup:Quote:
Originally Posted by SINISTR
Can they handle boost?
nice work mate. good to hear its all coming along nicely
