If you have been in an S2000, you do the same process to start the car. Put the key in, turn to "on", and then press the start button. So this DIY makes your prelude exactly the same. Yes.. it's for wank factor.Quote:
It would be nice if it were next to the key entry, but hey, nice work too...
You must be very experienced with electronics.
Just out of interest, does turning the key to the next click work too, or do you need to press the button now?
yeah mounting it near the key would of been better, ( like the S2000 ) but there is nowhere to put it on a Prelude on that side.
you have the option to disable the factory start signal from the key, this is described in the DIY on how to do it. you can have both if you wish.
my comment earlier man was why have the engine start down there when u can replace ur current ignition barrel with just the button looks more pro that way
http://www.crxaustralia.com/forum/at...4&d=1139276927
http://www.crxaustralia.com/forum/at...3&d=1139276914
^Anyone wantin to thieve a crx in the west melb area,there will be an easy one available soon.Just brick window,hop in,press start button located where ign key used to be & leave courtesy letter for not having to bend under dash to hotwire :wave:
Damn u ECU-MAN,was just eyeballin my broken starter wire yesterday after i ripped the crappy immob out that came with car,and talked myself out of puttin a stealth start button under dash,coz i got to much else to do.
Now i want a visual start button.
Gotta stop reading your posts :thumbsup:
yeah dudeQuote:
like CRXer says, it poses a major security risk, you will loose
ignition lock of the steairng wheel,
factory immobiser
you will have to install a switch for the ACC and IGN,
bling it all the way dude :)
Quote:
Originally Posted by CRXer
haha u SO.B :mad:
bloddy fantasic
is that UR lude ecu man ?
damm looking hot .. type R gear boot , skunk knob, s2k wheel ... and now s2k button ... farkn nice .
just a quick question la, the wiring you mention, tis the same in a 4th gen lude i take?
its not my prelude preludacris, but your right its a very nice ride.
as for the 4th Gen, the schematic will work on any car, the colour code is ment for a 5th gen but you will find its a Honda standard, just test with a test light before you commit to a particular wire.
