For anyone else that wants to try this you can get the same result in 5 minutes if you do the following:
- lift out the white coolant bottle
-lift out the snorkel
- undo the 3 bolts holding the air box down
-lift out the air box
-pull off the rubber seal from the bottom of the air box
- put everything except the rubber seal back where it came from
Done.
This way you don't have to take your bumper off and risk losing screws/bolts and the end result is the same.
