Quote:
Originally Posted by TypeG
Now that is going to be a problem, it really depends on what modifications you have, they will do almost anything to try and link the idle noise to your mods.. I'll be careful with them... Good luck
in the worst case, how much is the value gap adjustment usually cost?
when i bought my car second hand from a dealership it had a similar noise. Took it to honda for a service and an inspection. They removed 6 bent valves. 3k later, all good. Hope you aint bought a lemon like me.
i bought it brand new.......
when i bought my car second hand from a dealership it had a similar noise. Took it to honda for a service and an inspection. They removed 6 bent valves. 3k later, all good. Hope you aint bought a lemon like me.Quote:
Originally Posted by pilotb777_300
No more than 1 hour labour. It requires no parts and only takes around 20 minutes at the most.
-Remove rocker cover
-turn engine to TDC
-Adjust four valves
-turn engine 180
-Adjust four valves
-turn engine 180
-Adjust four valves
-turn engine 180
-Adjust four valves
-reseal and put back the rocker cover
Funny you should mention that, it is the precise feeling I always get when talking to any sales person, very polite but the balloon above their heads saysQuote:
"Just another idiot of a client I have to suffer" perhaps we should start a thread on this. I thought it was just my Honda dealership!
Adagio
Good
then i hope Honda will do it for free
what is turn engine 180?
Quote:
Originally Posted by EuroDude
adagio...
I dont know which dealer u go to but mine is the worst ! I got into a whole fight with them a week ago about oil... I rocked up with my own shell helix ultra and I politely asked them to use it... I knew they wouldn't do it willingly but the crap I got from them was beyond a joke ! in the end they refused to do it, saying they dont wana be liable for any engine damages... I told them I was an engineer as well with many years experience in designing aircraft engines and I'll take full (in writing) responsibility for whatever happens... in the end they bascially said we'll do it but they won't fix any engines problems under warrenty if it does come up. so I said fine I dont wana service my car today and left. I took it to another mechanic down the road who does lots of Bemmers and Audi's and he said he gets a lot of honda customers cause they r fed up with honda prices and service. Anway it all worked out ok in the end.. I will never be going back to a honda dealer and if something does need to be fixed under warrenty, the mechannic says he deals with the dealers himself to get it done so I dont have to worry about it. I hope not everyones experience with honda is as bad as mine !!! cause appart from the dealers, the car is the best I have driven so far !!! :)
There is a socket behind the front left wheel where you turn/crank the engine manually using a long breaker bar to move the pistons/valves 180 degrees to position the tappets for proper adjustment.Quote:
My mech cheated and only rotated it 360 degrees at a time, causing weird engine performance which required me to do it myself, which is quite easy to do once you know how :thumbsup:
Good on you for going somewhere else :thumbsup: Many Honda owners would just take the dealer line and back down. If i was you I would call up the Honda Customer Care number and complain.Quote:
Oh by the way - I went to a Perth Honda Dealer with 5 litres of Shell Helix Ultra (5w40 i believe - not the thicker 15w50) for one of my services. When I asked them to use this oil for my service the response was "it is good oil - no worries".
