how do foglights get stolen
I have no idea, but at least they were kind enuff for me to leave the wires hangin out still in tact. so now all I need is a pair of foglights bcos I don't need a relay or switch. I can just use the oem ones. ill see if I can get a picture up since the link aint workn.
I got 06 Euro. Is there any other option for fogs beside genuine Honda ones? I don't think those eBay ones fit 06 model bumper right?
Thanks.
someone on here is selling foglights for CL9...uz might be interested
http://www.ozhonda.com/forum/showthread.php?t=62715
it's better to get the OEM one i think.. it's precious and looks nice! :D
boleh, when you go home for holiday, go buy philips H1 bulbs.... cheaper and very bright also....
I have been considering fitting aftermarket spot/fog lights to my STD 05 Euro. However I was thinking along the lines of having them come on only when the headlights are on high beam, in which case a switch is not needed. I was planning to find the wire for the high beam supply and joining into it for a signal to a suitable sized relay. The main power to the relay and thus to the new lights coming from the battery via a fuse. That sounds simple or am I missing something?
should work.... fuse size must be correct, and I would prefer to have 2 fuse, one at the main power to relay then to spotlights, and another fuse at the high beam power to relay.
Attachment 4926
these are the foglights im talkin about. wat use think?
*bump
what is the difference between output wattage and consumption wattage? What are the specs of the stock fogs?
sorry to hijack, but do you know of any aftermarket foglights that use the same connector as the honda fogs? as i do not want to rewire the foggies in?
