I was thinking more like waste of money... all that cost for something that would make less power(presuming he dropped the c/r, as most people do) and be equally reliable as a stock internalled set up
if you've built it... use it!
agree, trying to empathise for the guy..Quote:
Originally Posted by saxman
Buy a A/F meter and raise boost mate, with forged internals and thicker head gasket, you should make waay more power from it.
a/f meter is absolutely worthless without a wideband to tell it what's going on
Yeah i am thinking or turboing my b16a2 but i wanna keep my internals stock....first im gona get a power fc...is that any good for turbo? is thr a different model of power fc if im going to turbo it or its the same one if im going to do a n/a setup? also wat turbo kits do u guys reckon and other mods...thxx
Quote:
Originally Posted by daniel b16a
Good choice on the power FC, i got one atm and they run sweet
a/f meter.lol
every tuner will you how sh*t they are, not accurate
youll find that you will want more power after you get use to it. ask anyone on here.Quote:
Originally Posted by J35T3R
Yep yep yep!Quote:
Originally Posted by jimmeh
Its a power addiction,
And for you to turbo your Honda, you're jst a confirmed addict :p
They tune cars with a wideband A/F meter FYI. That's how they get your A/F reading on the dyno.Quote:
Originally Posted by turbo convert
yes, but a lot of people install a/f meters into the car that hook up to the narrowband o2 sensor, which is completely worthlessQuote:
Originally Posted by Limbo
If you need a realtime A/F meter in your car then you shouldn't be on the road. Get the setup done properly on the dyno and your done. Nothing you can do once you see the meter reading lean at full noise cause the engine will have shat itself before you realise to take your foot off the gas!
