they lied.
they make 1L pre-mix blue type 2 coolant.
There is a reason. :) http://www.geocities.com/dtmcbride/h...ntifreeze.html
that site contain too much stuffs to digest.... Just get a Honda coolant for a peace of mind. :p
sorry to break the topic but how hot does your temp needle run ?
mine is like over a third...
Ranges between a 1/3 and 1/2 mark....
Using the coolant readout on the integrated radio/aircon display, my operating coolant temp is between 85-92 degrees. Lower on the freeway.
thanks guys, just that i thought it seemed a bit hotter but i guess it's normal.
I used to run about 90 degrees normal city driving. After a coolant change, it is 85 degrees. But not much info since the proof is in the oil temperatures (and I don't have an oil temp gauge)
just a general question.
if your radiator is full (squeezing pipe makes coolant bob up and down) but your reservoir is low on coolant, is it advisable tp top it up?
