Yeh the third plug is capped and has power in one of the wires.Quote:
Originally Posted by CRXerBUT this is the weird thing, while its cranking i can hear the main relay switching on and off quickly <-- is this normal? could my main relay possibly be farked? - but it was working fine b4 the engine conversion.No it should not be clicking rapidly,this seems like the prob.Recheck connections here,
Pin 1 = direct battery supply,thru ECU fuse in engine bay.
Pin 2 = ground,again, tee off black wire stated above for connection
Pin 3 = yell/black supply as discussed above many times.
Pin 4 or 6(depending on your relay) = supply off start position on ign switch(also goes to ECU pin B9)
Pin 5 = Supply off Ign 1 position on ign switch
Pin 7 = To fuel pump
Pin 8 = To ECU pin A7 (for fuel pump relay coil)
how do i check the PIN #'s on the main relay? all i can remember was:
YEL/WHT - ECU 15A
BLK/YEL - IG1
BLU/WHT - START Position
YEL/BLK - A15/A13 (IGN1/2 concerto ECU) and A25/B1 (IGP2 P30 ECU)
BLK - GRND A2/A4 (PG1/2 concerto ECU) and A23/A24 (PG1 P30 ECU)
GRN/BLK - A14/A12 (FUEL PUMP RELAY concerto ECU) and A7 (FLR1 fuel pump P30 ECU)
WHT/PUP - to O then ground ??
the above is how its wired up so far. but in regards to PIN7 & 8 wats the difference as they are both fuel pump? coz thats how my GRN/BLK above is setup.
I think my pin 7 is yell/black as well in crx,did u hook yell/black wire weve been discussing to this,instead of to pin 3 like it should be
Could it possibly be the way that my ignition to main relay is setup? - im just going off by the way the old ignition setup was.
I noticed that on the P30 ECU pinout it says IGP2 but my car does not have a IGP2, so the way the old ECU was setup with the 2 yellow/black wire was IGP1 <-- so this is where i connected the A25/B1 yellow/black wire, could this be why the engine wont fire up?Its just numbers for 2 connections of the ign.A25 & B1 should be bridged with that same ol' yell/blk wire off main relay.
dude my car is in my garage at north parramatta and yes it can be looked at after hours as im working as well. PM me if u can come around and give us a hand!!
