yeah... the pic is of the inlet side :P but thats kool I found them both... I couldn't see the other one because theres a small bolt in it. Obviously I've found it now though :P
just make sure your not looking at the cooling system bleed bolt,( its got a hole in it) I think its on the top hose housing anyway.
I'll go get a pick of it.
This is the one on the front with the bolt in it.
http://www.melbccr.com/phpbb/files/bolt_on_head1.jpg
and here is that other bolt but zoomed out this time... just confirming i've located the correct holes.
http://www.melbccr.com/phpbb/files/boltonhead2.jpg
No thats the Vtec Pressure Bleed screw
http://australia.pgmfi.org/automotiv...t_on_head1.jpg
bolt an anchor in the gearbox bolt in the red circle
Ok just as well you said something it could have gotten a little costly :P
OK Just so i dont bolt it all up wrong :P I just put a Bolt or one of those bolt things with a chain on it into that whole on the back of the head (intake side, near the cam gears) and on the whole down on the top of the gear box where a little braket sits to hold all the wires down there. and thats it... no other locations?
Yep try to use the anchor as a bolt thru the chain can be dangerous
you can find these anchors on other engines, just unbolt them and bolt them onto your engine
Ok Kool I have to get my maintanace crap tomorow SO i'll head off to a wreckers to take a look for an anchor. I'll put one of those back up saches aroudnd the engine just to be safe... be enough to hold it for a few seconds while i lower it.
