dc2 vtir seats dont fit into ek, tried it and one hole is abit further
dc & eg seats are the same. Ek seats have 1 hole different. I know some of the guys just running with 3 bolts (your life)
Suspension wise eg & dc are interchangable, EK fronts are the same but rear are different.
All Ek suspensions are the same hatch & sedan.
dc seats hey... have to hunt some down
the rear will fit, u either have to shave a bit off the eg lca as the fork is a bit different, the lca on the ek is a tad longer so this bit is also different i believe, to make a bolt on fit there are some companies that make custom lca's, (i shaved my lca on the old setup but the heat stuffed the bushing when shaving) if desperate get some new rear lcas that are made for a ek to eg swap.
EG hatch seats wont fit onto EM1 ( EK civic coupe) bottem left bolt hole dosnt line up needs an extra 2 cm... but the eg seat in an ek is soooooo much better =)
Whats need to it dc2 coilovers into an eg?
front straight fit and rear needs the control arms is it?
coilovers for dc2/dc4 should be straight fit to your eg(as long as its not an eg6 as they have dc2r rear lca's stock)
dor dc2r coilovers to fit you'll need the rear lca's off a dc2r or eg6
all eg's(bar eg6) and dc2/4 use a fork style lca at the rear
while the eg6 and dc2r use eye-style joints
thanks vinnY :D
Whats the going rate on a second hand set of lcas from an eg6 or dc2r?
around 150-200$
