Originally Posted by BlitZ
Is your car cranking ? i dont get it?
If its not cranking.. the first thing to do is to get it to crank..
you dont need antyhing for it to crank.. no fuel or spark needed..
Once that is soughted (maybe it is?)
Makle sure u got fuel...
Remove you spark plugs and crank the car abit first... this should give it some pre start oil pressure..
once done... put your nose on the plug hole and smell for petrol...
If not go to your back seat and listen for the fuel pump churning...
Once fuel is soughted check for spark...
Rip out one spark plug wire.. attach a spark plug at the end and place it need a rock cover nut..
Get mate to crank it.. you should see spark..
Once confirmed you will have starter, fuel and ignition.. then it should start..
Else.... im buggered..
Free to correct anything i say.. after all im a backyard mechanic... but all this has worked for me in the past and will just be the basic.. Further trouble shooting can be had once you figure what is missing..
