would u rather do the ECU check and take no more than 2 mins or drive 20km?
up to u man
up to u man
true!
i got an aftermarket dash though,
done this once awhile back! ill have to go research how to set this up again
any1 else besides ECU
could be a busted cat, does the exahust sound like it straining and a loud hissing sound?
nah it aint the exhaust system %100 sure..
basically what i have done. is take injectors out and change the fuel..
it goes back to normal after 2 mins of driving.. it wont go faster than 20kms!
have you checked the ECU?!?!?
So it changes after the engine has warmed up?
if you are confident you have tried everything you can goto a honda mechanic
habnt checked ECU, no time during weekdays
it isnt warming up the engine!
EDIT : i aint driving it, trying to fix it ;D
ill take it to mechanic on the weekend
i wouldnt even drive it mate
who knows what damage your causing
ECU check is ure friend...id find the code....would really narrow the problem down...
hey gfuys! thanks for all the rreplies i found the problem
Injector Filter, and oil ring.. need new ones ;D done a temp fix works fine!
injector filter?
or you mean regulator?
what oil oring?
