Run up to 45psi hot for road tyres.
35 psi hot for semis
35 hot for semi's is spot on. We start anywhere between 27-30 cold depending on the weather
It depends on the road surface temp.
this is correct you want about 2 psi less in the left hand tyres as there are more right hand turns they will heat up more same goes for camber slightly more -tive in the left than right
edit: you may also want to vary your tyre pressures front to back as you might want more in the rear than the front etc
If you plan on going back to wakefield on a semi regula basis it may be a good idea to start recording your lap times with your pressures and the temperature conditions so next tim you go you have an idea of what works and what dosent etc
