I will check all the fluids tomorrow. And yes, to remove the gearbox you either have to put it onto a hoist, which i dont have, or rip the whole engine out.:thumbdwn:
sounds like your pressure plate that is worn out, i had that problem before to when the car is off it goes into gear easy but when i start the engine it crunchs when it goes into gear sometime i cant get into gear at all
Had a look today, the fluids are fine and cylinders are all fine aswell. Got some help from the boys and they said its clutch so i'm gonna start ripping it apart soon. Maybe throw in a new hd clutch and fly while im at it.
Sang you aint having much luck man! how did the driveshafts turn out? did you measure them?
