Nah you cant really see it leaking anywhere. What I did was, I took it to a place where they have a code scanner/clearer, and they first of all will find out what code is coming up, then they clear they code from your ECU. Then you have to drive around until the ABS light stays on again, take it back and they scan it again to make sure that the same code is coming up and then they will be able to tell you exactly what your ABS problem is and what needs to be done to fix it.
