mine , 5th gear 100k, rpm is 4000, 110k/h ,rpm is like somewhere between 4000 and 4300
5th gear at 110 is 4000 rpm...
5th gear - 3700rpm
ah ok... i might get it check out next time on the dyno'ed...thats proabably the most accurate way
thanks for ya input
U guys stop speeding, speeding is bad mmmmkay!
VTIR @ 110 = 3.5 rpm from memory.
Type R are always 500 rpm higher than VTIR.
btw to confuse things, our speedos are not accurate hahah. use a gps and you will see.
yeh around 3500 to 3700 ! =) from memory
no 2 speedos are 100% the same. Nor accurate lol as said.
Also to make matters worse , those with conversions will run even less accuracy.
Also different tyre/rim size combos will put your speedo off more.
DC2 is 3400
DC2R is 3800
thanks for the reply
around 3850rpm at 110 km/hr
My DC2R is around 3600-3800 Rpm @110km/hr. It really depends on the set up in the car.
