Hello David,Quote:
Originally Posted by MRJDM
We do not carry any specific sleeves for the Honda B20 block. We used to but we ran into too many problems with the block so we no longer make them. You can however use our B18 kit 400-140 that is semi-finished at 84mm. But you may run into the same problems we did when we installed the kit. You will have to use sealer on the lower portion where the o-rings are on the sleeve. You would also need to make sure the bottom area is clean and smooth where the o-rings seat.
The cost of the kit retail is $560.00, shop price is $499.00 if you order just one.
Best Regards,
John Catapang
National Sales Manager
Darton International, Inc.
This is a direct reply to me from Darton about sleeves for the B20 and I have these kits in stock so if you need a price PM me.
Regards Dyno Dave
