Originally Posted by
claymore
EfiOZ maybe you can enlighten me. The problem I have with posts is this you are dealing with three metal expansion points. First you have the cylinder walls & sleeves, the posts, and then the other walls of the block to deal with. As we all should remember from physics classes when metal is heated it has to expand.
So lets start with the cylinders (and sleeves) if they have posts poking them on just two sides and they start to expand wouldn't the cylinder have more resistance to expanding at the post sites and therefore the unsupported sides would be able to expand easier making the cylinders go oval shape not round? And how could you check with the head on if this is happening?
Next you have the posts themselves from the physics classes again we know long objects like the post bolts expand longitudinally (down the long length not getting thicker) and since the cylinder gets hotter quicker it then expands out toward the post bolts but at the same time the bolts are getting longer putting more force toward the cylinder as they warm up so I would think you would be getting differing forces on the cylinders as they and the posts heat up at different rates and therefore expand at different rates as the cylinders are being heated by direct contact with combustion forces while the posts are just being heated by the coolant so I would think there would never be constant measurable force being directed at the cylinders because of the different rates of expansion and again how could you measure it with the head on?
And finally the outer block walls that the posts are screwed into. As they are the furthest from combustion heat they should expand the slowest of all three components. But the problem is the posts are screwed directly into this surface so while the the cylinders and posts are getting heated faster the block is getting less heat and expanding less slowly so again the forces being put onto the cylinders are being increased when the block is warming because the cylinders and posts are expanding quicker than the block walls but then when the block is fully heated it expands outward making the forces less because the screwed in posts are moving with the block outward making the force less.
So the bottom line is how do you work with/control the differing expansion rates of the three major components?
Until someone can explain how they solved the problem I'd vote against posting.
