like i said, not claiming to be an expert at all.
btw it was me who gave you that little red square :)
Thats right, small engine's with high rod/stroke ratio need cams with more overlap to take advantage of the scavenging effect, since they have low piston speeds. With a good header and exhaust system the exiting exhaust gases will create a low pressure area at the exhaust valve and if the intake valve is open at the same time the vacuum will actually help suck in the next lot of air and increase volumetric efficiency. Bigger engine's with lower rod/stroke ratios have higher piston speeds/acceleration and need cams with less overlap, or you might be able to dial some of the overlap out with a set of adjustable cam gears. If you have a bigger displacement engine with same geometry as the smaller displacement then there shouldnt be a need for a "larger" cam....
"So here we have a small engine vs. a large engine which have bore / stroke ratios that are identical at 1.14-1, and rod length to stroke ratios which were also equal at 1.75-1, so geometrically they were equal, and the cam (valve timing) identical, but the big engine didn't appear to me to need a cam with more lift or duration." -The Old One (Larry Widmer)
This is my understanding so far, correct me if Im wrong.....
http://en.wikipedia.org/wiki/Suction
Suction or to "suck" is the creation of a partial vacuum, or region of low pressure. The pressure gradient between this region and the ambient pressure will propel matter toward the low pressure area.
Thanks for trying though....
lol dude your post makes no sense.....
"The pressure gradient between this region and the ambient pressure will propel matter toward the low pressure area."
....this is the very definition of "suck", which means I did actually use it in the correct context and didnt need you to correct me.
If you read his post again, you will see it makes perfect sense.
Example:
If you are in an aircraft pressurised to 10,000ft, flying at 40,000ft.
Should a hole open in the side of the aircraft,
By your thinking you are sucked from the aircraft.
In reality, you would in fact blown from it. (Greater pressure in the craft)
Though it really is a perspective thing, physics is on Claymore's side.
The same applies from global weather paterns to internal combustion engines...
(Just my 2c worth)
Also... For the previous argument with Tink
Originally Posted by tinkerbell http://www.ozhonda.com/forum/images/...s/viewpost.gif
why did honda not change cams between B16A and B18C?
They did.
Actually they didn't... Only Type R is different (in the Vtec lobe only)
Regarding the B20 with the quads etc...
Regardless of theory,
Reality is a set of larger cams will work & work really well.
No arguing, just friendly discussion
Crower seems to disagree.... http://www.crower.com/cat/import/hon...s/b_vtec.shtml
With a similar set up to yours we gained 6Kw by repalcing the standard B18c cams with ITR ones then another 3Kw peak and 10kw in the midrange with a tune:)
Giday ZeForce,
Great posts, and that needs to be said!:wave:
I don't know why some of the above posters get so antagonistic when detail gets added to a post. It's got me F^(#&@!:o
Anyway, here's a starting point for you hyper-ventilating knockers....suck it up, it's wiki!!
http://en.wikipedia.org/wiki/Harry_Ricardo
ZeForce,
hmmm, probably not the same - with an engine with Variable Valve Timing and Lift Electronic Control feature...Quote:
Originally Posted by ZeForce
plus, we are comparing a B20B to a B16A...
these are not identical engines so NO the basic principles are VASTLY different:
B16A bore/stroke = 1.05
B20B bore/stroke = 0.94
B16A rod/stroke = 1.74
B20B rod/stroke = 1.53
one is "oversquare"
one is "undersquare"
simply "uncomparable" in regards to *breathing* requirements...
and since you love wikipedia -
http://en.wikipedia.org/wiki/Stroke_ratio
and regarding your crower stuff - i'd trust TODA AU over the Crower website ;)
Very true and I do actually agree. I was simply trying to point out to the thread starter that its not the increase in displacement which requires a bigger/different cam specs but in fact the change in the engines geometry....
Don't patronise me....
Check this out as well its from a completely different source.
http://www.myfilehut.com/userfiles/5...am%20Specs.gif
