Motul Turbolite 10-40 for daily use
Motul 300V when doing track work
I run Royal Purple, Its like $80 for 4L. Seems good.
for a old engine like your crx i wouldn,t use an oil too light as the engine would be old and worn say a 10w-40 or even 20w-50 and i wouldn, be using full synthetic oil in it either
For his 89, I'd use between 10w-40 and 15w-50 (D-series)
im with castrol formula R 25W/50 runs great, doesnt burn oil engines quite and it sure as hell does it's job!!
Car gets thrashed every single day
depends on how old the engine is really.
atm im only using castrol magnatec
Thanks very much for all the insight guys. I ended up with Pennzoil semi sync 10w-50. Seems nice and smooth and quiet and i put in a good purolator oil filter too. Ill be getting it all changed in a couple of weeks when i get it serviced anyway! Thanks everyone for your help
**** i just used some coolant i found in my garageQuote:
radiator fluid - honda or an aftermarket...tho make sure you pick your aftermarket coolant very carefully...its easier just to use hondas
after a hard drive i found the level has risen over 'max', normal or not?
and its okay if the resoivoir reaches over max
