are you sure it's not the bearing in your gearbox gone?
How olds your clutch? if its worn it could be slipping on its rivets
lol, how can it be fixxed
To fix it would mean a new clutch plus the labour involved in doing it.
Just get it checked out by a mechanic first before you go out and start blowing money away.
nah the clutch is fine, its like new does not slip at all, im worried about the bearings in my gear box dont know anything about them
I have a friend with a dc2 vtir and his spigot bearing on his fly wheel failed causing a squeaking sound. As for the gear box if the bearings are worn it would sound as if the gears are crunching or grinding under load
