So the end result to the question is???
Save up and build it to completion or is it ok to build it and add parts + raise limiter later in it's life?
build it bit by bit - or all at once,
the running in process is going to be tryign to do the same thing - seat the rings.
i think you will be able to seat the rings whether your self imposed RPM limit is 6000 or 9000...
once it is "run in" then you can add the fully built head and then get it tuned - (crossing your fingers it actually makes power upto 9000rpm)
take for a kinda similar example - my B20B - most of its 20'000km life it was in an automatic CRV, reving to 6500 MAX, then i whacked a B16A head on, now it revs to 8000rpm..
no issues.
