Originally Posted by
TODA AU
The pedal should feel identical to std as a std cover is used.
If the take up is toward the top of the pedal,
1st bleed the clutch lines properly,
2ndly adjust the pedal height.
If the problem persists it is likley there was an error in instalation.
The clucth should not feel different to standard in any way as flyhweel weight or inertia place no part in pedal feel.
Regarding Exedy,
As mentioned previously, Exedy also have an uprated disc.
The cover is the same as std however & genuine Honda.
