lol im gonna do that now, show these biatches who i am lol
nitrous oxide isnt forced in anyway - tis a additive . Moved to noob section.
HAHAHA... this is sounda good idea :p NOS ZC ^^
NOS gonna help you clean out youR combustion chambers. Which includes
Intake VALVES and the wall area.. it will give you a better results for the long run .. u might notice some efficiency gain after couples of NOS*taking note* not 24/7 purging it LOL
WELL THATS THE THEORY !! can any body confirm it ? thnks :)
lol man you have the worst ideas - first it was a 180sx coz you dont want to understeer, now NOS
i reckon the best bet is for you to get a ride in a car with nos, then see if you like it.
if youre worried about not being able to control your car, nos probly isnt the way to go
ffs mate, jus buy a faster car ;)
is NOS illegal if you drive your car on the streets aswell?
say u use ur car for track and street
will u have to remove the nos tanks everytime u drive on roads?
(chunky) basically yes.. if you get pulled over, the cops would probly give you a fine.. and make you take it off.
(serpo) will your car take nos...well It all depends on the application. A "wet" kit is ideal for both normally aspirated applications as well as forced induction applications. It can require a little bit more installation time than a "dry" kit, but is easier to tune if greater than stock HP settings are to be experimented with. A "dry" kit is excellent for normally aspirated combinations that have a return style fuel system. They are very easy to install and are a great "first time" nitrous system. It is not recommended that "dry" systems be used on forced induction engines.
on a dry nitrous setup mostly u should only run up to a 75 shot and not over.. the reason why is.. U have no fuel added for this setup!!! dont even try... it would be stupid! anyways.. back to what i was saying... on a dry kit u have no added fuel so when u "spray" as we call it u arent adding any fuel so therefore it is unsafe to go past a limit of fuel to air ratio.. in retrospect, this would make u go lean going above those settings... but myself, i like Wet Kits.. U r adding fuel and can go up to a 125 shot from what i have seen built honda motors take on something other than a direct port setup... so that being said, here is where i will break it down and get in the info i want to....
on a Wet nitrous kit u are adding fuel to nitrous instead of A) the computer compensating.. or B) u doing it manually.. the kit, or "nozzle" is doing it for you.. now what this does is optimize fuel to air ratio by adding what else, fuel and somewhat air... this allows the engine to take more with out damage because of the added fuel... now b4 i used to love my dry nitrous kit from ZEX. the reason why was ecause u had that neat little box and u could hook up the Vac line to the FPR and basically increase Fuel pressure with more vac and basically make the FPR think it is seing boosted conditions and increase fuel. Cause nitrous is a form of FI then u must need more fuel, most of the time anyways, that or your engine will like it more in FI moments anyways, for a better A/F ratio. Kk, so now that we have talked of the ZEX the reason i liked it as because i couldn`t tune my car, the reason why, no extra fuel after spraying because i was only injecting nitrous and not fuel. So some good nice ass fuel managment was out of the question for me, i went from I/H/E and a Straight pipe/Test pipe with the nitrous jet at a 65 and the fuel jet (yes, even though it is a dry kit, it uses a fuel jet to regulate the "bosst" that the FPR sees to corespond with how much nitrous is getting used) at a 75 shot, the reason why was because i thought i was injecting more fuel. wrong!
even though ZEX claims to be the "safer" kit they do really baby there stuff and that is why it is "safer".. what i mean is, NX, NOs and all the other kits that are alike rate at the wheels for HP, and the ZEX kit is rated at the flywheel. That blows because that mans using a ZEX kit u will make less power than a NX kit or other, doesn`t sound right does it? ok then, so again, i went from that setup to a NX wet kit, the reason why i like it. i can finally use some bomb ass computer softeware to tune and still use my nitrous because i am injecting fuel and nitrous now, so technically my A/F ratio should be the same all the way accross.. so this is what i did.. i had my new nitrous kit installed and hit the dyno, i tuned with my SAFC for a little it and pulled a couple ponies and some better MPG, which is awsome, cause with the rising gas prices tuning may actually be in mind for more people to squeeze out a couple reliable HP and more MPG.. so that being said... i tuned and got a nice A/F and then i started thinking, so my mind was racing and i hit my work (AutoZone) and picked up some Bosch super plugs (DO NOT USE PLATS.!!!) anyways, put em in and was happy to see what kind of A/F`s i woul see with nitrous, so i made the run.... and was psyched when i found out the results, awsome air/fuel ratio, this thing rocled i mean, perfect, and even though i was at 60 HP jets i felt comfortable using this kit, it made me more at ease knowing that i was using fuel also...
Gotta remember it costs $110 to fill a 10lb bottle with nos which will last under 2 minutes even with a 50hp kit.
