sniff it lol
sniff it lol
do as stated and park overnight and look at the puddle in the morning.
First thing to determine to help narrow things down between engine/gearbox would be oil colour... then take note of whereabouts the oil spot is he ground compared to your engine bay..
Parking it overnight and seeing where the oil leaks are on the ground is pointless as it can run down the block, then across the cross member to the other side of the car before dripping onto the ground...
So the stain could be on the left side but might actually be leaking on the right side of the motor...
Just take it to a bloody mechanic and you will be able to see it, clear as daylight rather than pointlessly wondering where the **** its coming from
Seriously it will take like two minutes
Stop wasting your and our time...
The bolts above the oil filter i believe is where the oil pressure sender is.
It usually does not leak unless you've been playing with it.
You gonna have to clean the entire area, then go for a drive and watch for where the oil is leaking to precisely locate the oil leak. Then its a matter of replacing the seal that is leaking. Usually abit of gasket glue works well.
P.S Their right do not over tighten the oil filter. IF its leaking from the filter you need to take it off, clean the seal, apply some oil then screw it on properly.
oh relax Drew, everyone's here to help
no need to be a complete moron about it
I'm not being a moron about it... you are
lol ok
