Originally Posted by
LXRY
Mine was doing similar drift to the right in 3-5 secs on a straight road at 5,000klm, honda dealer adjusted my subframe, did not drift on straight road any more, only under right camber, excessive !!. Ever since they adjusted my k-frame steering out also....K-frame only a band aid solution, to counter the pulling drifting to the right. Changed my tyres still pulling excessively right going to get my k-frame straightened seeing as I just changed tyres....if it's the bridgstone reo40's then should track straight again steering wheel should be straight then aswell....hope this works.
Do you have bridgestone reo40's?
Might not be your fault report it to your dealer, go in there with the knowledge you have from this forum about the drifting problem other euro's have, be firm.
Don't even mention anything bent or what alignment guy said, see what they say.
Keep us posted
