Nah man, dont know much about electrical... :(
ok just clarify 2 things for us..
when you say it just chokes. does this mean it will still crank over as normal and the dash light are still on
and
when you have to wait for the electrical to tick, you mean you hear a tick then it will start , however if you dont hear a tick it wont start. if so then what tinkerbell
said could be the problem main PGMFi relay
yeah lights r still on & engine just cranks...
when she wont start yu need to check for spark. also have someone look at your main PGMFI relay, they can be repaired.
make sure you have the correct earth bolts fitted to all earth cables and also check if the main earth battery lead hasnt turned green, si civics have aknown problem with earth cables
it sounds like your main relay might be on its way out...Quote:
Originally Posted by Si1enzio";p="105807
this is under the dash, and is usually brown and about the size of 4 matchboxes on top of each other.
this sends the siganl to the fuel pump to make it pump,
if you look under your dasha nd can find the main relay, with the battery disconnected, remove it and swap it for a known good one ie from your friends cars, and see if it solves the problem...
these cost very little from wreckers...
Def Main relay problem. Check out the other thread.
