just post update to let everyone engine idle has been improve after change the transmission fluid and flash, also the engine oil changed.
Nice. Good that your problem is fixed.
My idle sometimes sits at around 1100rpm after releasing teh clutch for no apparent reason, its not the fuel burn-off thing because it can sit there for like 10 seconds (fuel burn takes 1 second). I noticed that if you hold the steering wheel to one side while idling, the revs will go up a bit, but thats not it either as it happens when the steering wheel is not being held. It will finally drop down to 700RPM after a while. Im guessing its the ECU doing something
But anyways most of the time its about 700RPM so its all good
^ You're probably right, I guess the engine needs to keep the revs up for longer since the revs are so low near idle speed.
