on accords the buzzer is inside the white modual bolted on the interrior fues box, intergra and civic its the same thing. I thing the buzzer is the same one as the lighs on warning.
I believe the buzzer is part of a FUSE... Not sure which one...Quote:
Originally Posted by tegraa";p="109257
thanks for the advice ecu-man, much appreciated but i dunno if the beeping sound is that annoying for me to go through that hehe
my friend with an integra type r says the beeping sound in his car is not as loud, is that true?
It will vary from modle to modle. another good idea is to find the piezo, and stick a piece of sticky tape over its hole. it wont shut it up but it will be alot quieter.
thats trueQuote:
Originally Posted by davey";p="109528
i could live with the beeping from an '00 R, but mine is too fukn loud
Is there an easy way to disconnect this plug? I fiddled around for a bit and it wouldnt budge for me!
what car dude and which plugQuote:
Originally Posted by VTEC Inside
94 VTiR Integra, plug under seat to stop is seat belt warning
yeah i there is an ez way to remove it..
i fiddled with it 4 a while then worked it out, but 4got now :shock:
i think u press something and it come off, ez once u work it out...
u can slide out the plug out from under the seat and then play with it 2 come off..
ill check it out later and post it up if u havent done it yet :)
i have a 94 vtir and pretty much just pulled it apart. just have a little fiddle and you'll work it out. take a torch if things become really tough
ok thanks i will have a another try today, i suppose i can't just cut the wires can i?? It sounds like a bad idea though...
dont cut the wires dude. the connector is so easy to undo, you push in the tab on top and pull out at the same time.Quote:
