Hey John,
My car had around 12ish CR runs fine. Just get a good tuner (Y)
Hey John,
if it helps you we have run 13.1 on optimax, but u need a fair bit of work done to the support systems and a full system like autronic, motec and EFitechnologies to make it happen.
My car running in the "high 12" to 1 compression. It run fine dude :). U just need a good tune :).
I recommend dynodave if u can get him to tune it. Though his a busy man these days.
Regards,
David
I think my CR would be around 12:1 wouldn't it Dave?
So it seems the fuel quality itself is fine, the key elements are really engine set up and tune.
Too easy
Ok here's my turn to get flamed. (i was bored at work)
From my memory of combustion, the reason for higher octane fuel is to stop pre detonation of fuel on higher compression engines.
Thus a good tuner should be able to tune it to ensure that your timing is adjusted enough to prevent predetonation.
I know on my 20v with the head shaved it increased the compression, but i dunno how much. It was then tuned and it was fine running 98 ron. Just make sure you get the fuel from a reputable place to ensure consistent fuel. I was told that most engines are built with a tolerance and a few mm and upping the compression slightly with a good tune was fine. The engine lasted ABIT, but i wore my piston rings pretty quick, but then i was revving to 9krpm alot without upgraded internals.
Comon Dyno Dave give us the answer now.
Its not just timing that ur worried about limbo, in effect ur limited as u have mentioned by the fuel your using and the system around it in controlling predetonation. Timing is only one element u need to keep in check, predetonation isnt caused solely by timing.
For example, Pat (efiOZ)and myself have used in excess of 16:1 CRs on racing fuels, but the racing fuel alone isnt the sole reason that we can run 16:1, its the combination of the parts that we use that allow us to use 16:1. If we were to put normal street fuel into that thing, it would literally blow the thing up. If we changed another factor for example the restrictor size, but kept the 16:1 Cr and race fuel, the engine would still grenade itself.
to run a high compression what are you planning on running as in what supporting mods are you planning on doing like sleeved block, ur bore size, rod lengths, head work etc....
