lol
all good mate
lol
all good mate
where do you put dynamats anyway? is it on the outside of the door panel surrounding the speaker or in the inside of the door?
I'll do it based on priority below:
sd inside of the door
cover the service holes with mdf
if you have some more dynamat, then sd the panel surrounding the speakers
if you even more, sd not only the surrounding but the whole door.
this website helps alot:
http://www.caraudioaustralia.com/
btw: sd -> Sound deaden
will this help the cabin keep the sound of a drony exhaust out? (cars a dc2 btw)
if you use enough - yes.
Overhaulin' style, slap it everywhere and anywhere. Make sure you use truck loads of it then have a big budget to build a 10 sec 1/4 machine as with 10 bulk packs of dynamat to kill noise you ain't gonna be accelerating very quick OR you could put the factory exhaust back on to stop the droning, I know what I'd be doing if it came to putting weight in my car :p
Then again if you had the budget for both your still out of luck as I think Chris has already mentioned the importers are out of stock of bulk packs, candy anyone? :cool:
