What do you guys think of this 4 in one gauge from speco, its $300 and comes with a 1 year warranty. http://www.speco.com.au/tachos.html Its the 5th one down, on the left.
Does anyone have any experiance with this tacho, or any speco gauges for that matter. Im a little concerned with quailty, as they are on the cheaper end of the scale.
Also, you can mount gauges like this into a flat panel correct?Quote:
5" 12 volt 4 in 1 memory recall tacho
0–12,000 rpm, with oil pressure (0–100 psi), water temperature (0–0120º), boost (0–30 psi), external shift light, 12,000 rpm dial, red back lighting. Includes electrical senders and boost gauge line kit.
