could it also be from bent LCA etc ?
warp rotor should make my steering vibrate at high speeds would it? maybe something else?
when rotors are warped means that the disc brakes are not straight anymore, and when they are spinning a section of the rotor gets closer to the pad then the rest of the disc, this causes the steering wheel to shake,
so basicly when the disc is moving through the brake caliper a section of it isnt even and sort of slows down faster then back to normal, then faster again
hope u under stand that:p
warped rotors are cause by u over heating the disc, and not letting them cool properly, sometime can be caused if u heat up the brakes alot then just park the car, the rotor cools down but the bit in the caliper doesnt, ie gets warped
in addition to czy sols reply...heres a senario of how it can happen.
heated up disc then running through water or washing the car straight away after a good drive.
what about his other problem i would liek to know too. i get that sometimes when travelling at high speeds my wheel shakes abit.
^^maybe ur shocks or bushes are bout gone??
ok i want to get my rotors checked out. do i take it to a mech and they will sort it out on their machine or how do i check it so i know which rotor is gone and take it off myself ?
do i need to do a alignment to find out or what? thanks
Hey mate, this sounds very similar 2 having warped disk which are the cause of brake shudder which have very similar symptoms as stated above...
to test this u can measure ur disks in 4 different spots around the disk 2 see if it is equally warn...
but this also seems 2 sound like the affect of ABS (i dont know if ur car is equipped with ABS) but if it is, this could be what this shuddering/shacking and that faint noise is....
basically the ABS system is locking and then unlocking the brakes very quickly preventing them from locking up... - i experience going down the straight at wakefield at 150km/h and putting the anchors on after the kink...
hope this information has helped :)
thx shifty! ++
yes my car is ek4 does have abs. so maybe it is also abs ? ok well i have it checked out. i have always had abs but never this bad if it is really the abs.
how do i go about measuring the rotors ? what do you use?
